Hi Techyv members. Can you tell me how to download SSW code auditor online? Please include your own review of the product. In terms of efficiency and reliability, how can you evaluate this? I'm looking for the best code analysis tool out there. If you can give me an overview of this tool, then that would be awesome.
How to download ssw code auditor online?
Hi Roger,
SSW code Auditor is a code analysis tool used to maintain and debug large source code. It simplifies the whole process of maintaining code. Below is an analysis of the features of this code auditor.
1. It validates HTML codes using a Tidy HTML engine.
2. Performs scanning of directories.
3. It has the ability to organize different projects into jobs for easier management.
4. It checks for code that violates set rules. In addition it has a Regular Expression builder that helps to define more rules.
Some of the benefits of using SSW code Auditor include
1. It ensures quality control of source code.
2. It has a powerful and user friendly interface.
3. When using it, the code audit is customizable.
Generally, it is a software that is reliable and has high user ratings especially for its simplicity.
You can check this link to download the software https://www.ssw.com.au/ssw/codeauditor/
