How to download telugu script tool?
What is a telugu script tool and how to download it over the internet?
I want to learn more about this tool can you give me some suggestion base on your experience regarding telugu script tool?
I need your help experts.
Thank you.
Best Answer by Riley weaver
Answered By 60 points N/A #134841
Hi Richard M Logan,
I have researched some possible sites that may solved your problem.
I have attached some links that may also help you in finding the best solution with your concern.
APOnline Approtal Telugu Software
Telugu Changathi Fonts
Hope that it would help you.
Thanks and more powers.
Answered By 10 points N/A #134842
Hello logan,
As far I have searched I did not have any tool for Telugu script.
But yes there are some websites that can help you to learn about it. I can suggest some of those sites.
But first of all you need to know about the basic idea about the fonts, also you can take some help from Google translator.
To learn about Telugu scripts and also to discuss sometimes you can try this link:
You can also get the fonts here
Yes of course you can get a tool but I think it does only can help you about fonts.
Although you can choice in between these but I prefer you to go through Wikipedia and just look at those fonts and take a little teachings from there about the alphabets at first. I Hope that can help you to learn early.
Best regards
Riley weaver.
