How to download USB erd commander 2007?
Hello experts,
How to download USB erd commander 2007? I need a freeware version for this. Tell me some of the advantages and disadvantages of the feature of USB erd commander 2007. I am very curious and want to get one for my windows 7 64 bit operating system dell laptop.
Thank you.
Best Answer by Mckinney Ma
Answered By 25 points N/A #165355
Hello! Good Day!
ERD Commander is software for diagnosing and repairing faults on unbootable computers. It is a very powerful tool.
Feel free to visit this site for tutorials on how to create a bootable USB ERD commander.
http://sagistech.blogspot.in/2008/10/how-to-create-erd-commander-to-boot.html
http://calmit.org/erd-commander-2010-vista-windows-7/
Just remember to set your BIOS to boot first from the USB.
Hope this helps!
Answered By 0 points N/A #165356
Hi
ERD Commander is contained in The Microsoft Diagnostic and Recovery toolset.
This is very powerful for diagnosing and repairing faults.
Creating a bootable USF driver for ERD commander from an ERD commander ISO file is not a easy process.
So I will tell you a alternate way to create this. For this you should download a simple tool called YUMI-Multi boot USB creator, this will provide easy way of making a bootable USB flash drive for ERD commander.
Step by step process
  • Download & Run YUMI-Multi boot USB creator
  • Select you USB drive
  • Select a Bootable ISO
  • Browse to the ERD50.iso file location & open
  • Click on “Create”
  • YUMI imports the ISO file onto the USB drive
  • Then you can boot your system & you can a menu to choose what to boot from
Thanks & Regards
Mckinney Ma
