Trevor Jhon
40 points
Posted on - 09/27/2012
How to download Visio shapes digital systems? Last time was a very disappointing download for it doesn’t go through it just stocked up and never continue and it doesn’t have to do with my internet connection because it is perfectly fast. I need your help guys for the downloading process will push through.
Thank you.
How to download visio shapes digital systems?
Well, sometimes downloading visio shapes digital systems may throw errors if they are not properly downloaded or installed. Follow the steps given below and you should not face any disappointment –
1. Create a new folder titled "visio" in the following directory: C -> Program Files -> Microsoft Office -> Visio10 -> 1033 -> Solutions.
2. If your "Program Files" directory is not listed under "C:," then navigate to the "Start" menu and select on "Search," "For Files or Folders." Enter "*.vss" in the open text box below "Search for files or folders named:". Right click on a .vss file to get its properties, which will provide you with the correct path. Then follow the same steps mentioned listed above.
3. Download the files to your local hard drive. Use WinZip to extract files to a temporary folder. Copy all files into the "Visio" folder in that directory and you are done.
