How to download visual basic bird hunt?
How to download visual basic bird hunt? Any sample code for the game will do because this is related for my task and I also want to study more about this.
Thank you.
Thank you.
Jeo, wassup?
I will be glad to help you in your query. The visual basic bird hunt can just be downloaded manually and simply in several websites such as software.informer.com
Just go to the website, download the files and save to your computer to install them with the birdhunt game.
You are going to get the codes and once you install them together with the game, they should be able to work well.
I hope this solves your query
Thanks
If you are looking for a sample code for a duck or bird hunting game, try the following:
