joelabrame
10 points
Posted on - 09/07/2012
Hi Experts,
I need to download we ve video converter ultimate.Does anyone know where I can buy this software?Will be available for purchasing in amazon.com?I hope to buy the licence copy of this software.Thanks.
Joelabrame
How to download we ve video converter ultimate?
Hello Joelabrame! You can download and buy the Xili Soft Video converter ultimate in their official website using your paypal or credit card to purchase the license key of the product. And the downloads for Windows platform and Mac OS is also available for purchase. if you want to purchase the ultimate version the price is $59.95. Here is the link for their official webpage Video Converter Ultimate
I’m not sure if there’s such a program called “We Ve Video Converter Ultimate”. Can’t find it on Google either. If you need to have a video converter, try ImTOO MPEG Encoder. I have the Platinum version and it works great supporting so many audio and video formats compatible with devices such as iPhone, Apple TV, iPod touch, BlackBerry, Sony PlayStation 3, Sony PSP, Nintendo Wii, Nintendo DS, Xbox, and Zune.
ImTOO MPEG Encoder supports Windows XP Service Pack 2 or higher, Windows Vista, Windows 7, Windows 8, and Windows 10. It requires 1 GHz or faster Intel or AMD processor, 256 MB RAM, 50 MB free hard drive space, 16-bit or higher video card, and 800 x 600 screen resolution. The application doesn’t only convert audio and video files but it can also make changes to the file.
You can select which part of the video to convert by specifying the start and end. You can split the video into several smaller video clips according to file size or duration. You can also remove the sound or mute the video as well as extract the audio or video from a file.
You can change the screen dimension or screen size of the video and make it bigger or smaller according to your target device.
