How To Download Windows 7 Iso Home Premium?
When I bought my dell laptop, Windows 7 iso premium was already installed on it. But, it started dysfunctioning so I had to remove it. Now I want to reinstall. How to download Windows 7 iso home premium?
Before you begin your download, you need to have the following things with you:
First, the product key should be accessible to you.
You should have an internet connection with sufficient speed.
There should be enough data storage available on the computer. You should have gone through the system requirements given here:
https://support.microsoft.com/hub/4338813/windows-help
Then, log on to this website:Â https://www.microsoft.com/en-in/software-download/Windows7
 Enter your product key and verify it. Your download will start.
