How to download windows media player galaxy 05? I want a free download for this kind of application. I just got my new galaxy 05 and I want the best features and downloads to be applied on it, but before anything else I want to make the best out of it and to secure that no viruses can enter the system.
If you are pertaining to a Samsung galaxy phone model, you can download an alternative media player found in the Google play store it is very safe as it is moderated by Google. You can access this in the application icon found on your home screen.
Click play store and you will be presented with several applications featured / top 10's etc. To look for a media player tap on the search button located in the upper right corner ( the one looking like a magnifying glass) then the works video player or media player. You will be given several selections either free or paid.
The Samsung Galaxy On5 Pro is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public and released in July 2016 measuring 142.3 x 72.1 x 8.5 millimeters and weighing 149 grams. It uses dual micro-SIM cards and has TFT capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution.
It supports multi-touch and runs on Android 6.0 Marshmallow powered by Exynos 3475 Quad chipset, 1.3 GHz Quad-Core Cortex-A7 processor, and Mali-T720 GPU. It supports microSD expandable up to 256 GB. It runs on 2 GB RAM with 16 GB internal storage. The primary camera supports 8 megapixels with f/2.2, LED flash, and autofocus featuring geo-tagging, face detection, and touch focus.
It supports 1080p video recording at 30 fps. The secondary camera supports 5 megapixels with f/2.2. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with Wi-Fi Direct and hotspot support, Bluetooth 4.1 with A2DP support, GPS with A-GPS and GLONASS support, FM radio, and microUSB 2.0. It has built-in accelerometer and proximity sensors. The pre-installed web browser supports HTML5. It runs on removable Li-Ion 2600 mAh battery.
It is available in black and white colors. Windows Media Player doesn’t have an Android version but you can download many different media players on the Google Play store. One media player you can try is Media Player for Android. Another is VLC for Android. This is the Android version of the popular VLC media player on computer.
1....
