How to download winxp sp3 repair?
How to download winxp sp3 repair? I am using a windows xp operating system which is compatible to this. Anyone of you where can I get a freeware version download?
Hello.
Do you have the installation disk of windows xp sp3 or an iso file?
If yes, then you don’t need to download any kind of repair software.
Just place the installation disk in to the drive, after the dvd loads and runs the windows xp setup
There will be an option called repair at the bottom of the installation window
Click on the repair button and wait for process to continue.
This should solve your problem.
Thank you.
Hello Maxine,
Here i am going to suggest you about the clear removing of the problem. Follow the whole instruction after that you will successfully repair your winxp sp3.
IF you didn’t install Windows XP service pack3 here your free download link .
As preliminary steps I will suggest you to try manually for better installation.
Click > Start> control panel > add or remove > show updates > service pack 3 > click repair > then restart for repairing form boot. After uninstall, reinstalled a fresh new copy and click Express button after clicking update in sp3 downloaded page.
In a clear installed window XP before windows xp3, updates is not install after repairing that why uninstalled is needed.
Best of luck..
