How to download wow slider conflict?
I need to know on how to download wow slider conflict? There are some errors during my download last time with my current operating system which is windows 7 64 bit and I don’t want it to happen again. Any of you knows what is the step by step method or process that will lead to a successful installation and of course that is compatible with my operating system.
Thank you.
Answered By 0 points N/A #175477
Hey Kimberly,
Follow the steps below and should successfully install the WOW slider conflict –
1. Create a mission statement for the web site.
– What is the goal of your site?
2. Select a Hosting Company & their URL.
– Make sure your hosting company supports MySQL databases (“Mac.com” does not).
– Find a hosting company that supports “1-button WordPress.org installation.”
– You can usually bundle the purchase of a vanity URL (www.[yoursitename].com instead of the default www.[yoursitename].wordpress.org).  This is usually not recommended by some developers if you should ever have to switch hosting companies.  But, it can be simpler and cost-effective to have a single account for the recreational user.
3. Install Worpress.org.
– When you install WordPress.org with 1-button install you might be presented with the option to install in the root folder or as a “subdomain.”  Setting your account up as a subdomain allows you to have one hosting account with multiple WordPress.org blogs in it.  Using this structure is a cost-effective choice for users with multiple blogs or for designers with several small clients on tight budgets with limited traffic.
4. Select a theme design for your site and customize it.
– Note that only some themes have a graphic banner header option.  You can replace the banner header image with any image you desire.  Your image should be a “jpg” type file and should be 72dpi.  The height and width should match the banner size of the theme image (found under “Appearance>Header and should read something like “1000 x 240 pixels”).
–  Themes are like fashionable outfits.  You can change them even after you’ve developed your blog with content in your pages and posts.  You won’t lose any content when switching regular themes, but keep in mind, elements may be hidden if your new theme does not show elements from your old theme.  It could be something minor like listing tags for an article under the title to losing widgets from a missing secondary sidebar.
5. Start blogging.
-Write posts to document fleeting things like events and unique thoughts on singular topics.  Use pages for fixed information.
-For the theme I’m using here (twenty-eleven), the pages I’ve created automatically appear in the tab section just below the header.  The “Home” page shows posts I’ve written with the most recent appearing at the top.
6. Promote your new blog or website
