How to download xbmc windows 8 tile? This is to manage the utilities of windows 8 operating system. I want to download this kind of software but how and what are the steps to be followed so that I will get a secured and safe downloading and installation process. I hope you will help me,
How to download xbmc Windows 8 tile?
Hi Kristen,
You can go about the procedure described as above.
Alternatively, you can download a software to make things easier for you. This way you can get the desired result without worrying much about the procedure.
You can download the software from the link given below.
Link: http://windows-8-transformation-pack.software.informer.com/1.0/
Hope this helped you in your query!
Drianna allen
