How to download xml to owl converter?
How to download xml to owl converter? What is the correct step by step process of downloading and installation for xml to owl converter? Give me some advise and tips guys.
Regards, William.
Regards, William.
I do not see any downloadable software for converting XML to OWL, but there is a free online converter that works fairly well and many users use it for the same purpose. You may visit the website by clicking the link below.
https://dl.acm.org/citation.cfm?id=1953376
If you really want a downloadable version, you might want to contact the researchers of An Efficient XML to OWL converter. It is possible that they are selling the software and you could purchase it from them. Check out the link below to know more about it.
Hope this helps. Good luck!
