How to download XP internet security 2011? This is to protect my windows XP operating system from harmful viruses and malicious ware downloads. I need your help on what website I can access a free download.
Thank you
How to download xp internet security 2011?
XP Internet Security 2011 is not a malware remover or protector at all. If you want to protect your pc from Malware install any registered antivirus such as Kaspersky rather than the software you selected.
The feedback of XP Internet Security 2011 is not so good. Â
Malware Bytes is an excellent tool for this purpose.
Browse here – http://download.cnet.com/Malwarebytes/3000-8022_4-10804572.html
LyanaHay
Hello Dudley,
 You want to download internet security 2011 for XP. But, I have seen that people referring to remove it claiming that it is some kind of fake antivirus program.
 So, I will suggest you to use Malware Bytes an antimalware program which is also available for free. Here is link:
www.malwarebytes.org/
Or get any other good antivirus program.
