How to draw a gun in txt message
How to draw a gun in txt message using ASCII characters and how to use it for the mobile phones or Facebook messages ?
Hi Raymond Adem,
In order to draw a gun in text file (notepad program for example), first you have to imagine how your gun looks like. Then, you use ASCII characters to draw your machine. Here I give you a website that has many guns in text:
If you want to use your gun in Facebook, you have to re-draw it using ASCII characters again in Facebook status.
I guess it is the same on mobile phones. But mobile phone screen is smaller than monitor or laptop screen. So it’s difficult for you to create big gun.
Hope this helps
Hi Raymond, that's quite an interesting question but I'm still in a good position to answer you.
Drawing a gun in a text message using ASCII characters is quite as easy as still writing the letter text! It just requires a little bit more of thinking!
Well, these are some of the symbols or ASCII characters you are going to use to draw a picture of a gun;
#, J, W, ", (,)
The drawing when you combine these characters would look like this;
,_____, /_/' .'====' /_/' ,-.______________,=========, [| )_____________)#######((_ /===============.-.___,--" _ "-._,__,__[JW]____########/ ( )) )####O##( ___/,.####### `====" ####### ####### )##O####| )####__," `--"" It would just need some clever combination and that will really work well in designing. I hope this is of help Thanks
