How to draw wave line corel draw
I want to draw wavy line in Corel draw, as I'm new to coreldraw I don't know how to draw wave line Corel draw. Anybody help me on drawing a wave line in coreldraw.
First draw parallel lines, interactive deformation tool in the toolbox and then select from properties. Click the zipper deformation field in the parallel lines of a pull back to form and then click Properties on the bar a little jagged smooth deformation, such a standard wavy line to become, then you will slowly adjust.
Try the interactive Distortion Tool, it' give up a ton of possibilities to create a wavy line works on text converted to curves, (CTRL+Q) to.
