How Durable are Dell Latitude Laptops?
Have you found Dell laptops to be very tough compare to other types of laptop you have used in the past? How much heat can they take without the components melting? What is the mechanical limit for Dell laptops? Has your Dell laptop been able to withstand a terrible fall? If yes, how come they are so strong? What kind of materials do Dell manufacturers use to make their machines so strong?
Answered By 0 points N/A #190565
Dell Latitude is a sturdy machine built for serious people looking for the best deal the market may offer. You could even drop it to the pavement and it will still provide optimum performance. It's shell is built with Tri-Metal technology and carbon-composite material, which makes it more durable. However, every material has its limitations in terms of melting. But this machine has a good outdoor suitability. In other words, it could withstand the heat of a direct sunlight and still provide good performance. I've used Lenovo ThinkPad, and Vaio and I would say that the closest laptop you could compare this with is in terms of durability is Lenovo ThinkPad.
