I have an iPod nano 5th generation that i have saved lots of my favorite music, categorized in various albums. I need to edit the albums per various artists name, but i have been trying to edit the albums to no success. Anyone who knows how to edit an album on an iPod?
Dana Cua
5 points
How to edit albums in iPod Nano 5th Generation?
Hi there, Jennifer.
Having an unorganized music files in your iPod can really be annoying. However, there is an easy solution that you can do to that. You just need to connect your iPod to your computer and launch the iTunes. Select the songs with the same artist, right click and click 'Get Info.'Â
Note: To select multiple songs, click 'Ctrl' and select the songs that you want to edit. iTunes will ask a confirmation to edit multiple songs after you click 'Get Info.'
Name the songs and if you want to put them in a folder just right-click your device and click 'New Playlist.' You can type the artist name and drag the songs to the playlist.
I hope it helped. Thank you!
