How to edit and set lord rings desktop icons?
Hello experts,
I have some lord of the rings edited picture in my local disk drives and planning to set is a desktop icon for my important folders.
How can I be able to set it as an icon for a specific folder?
Give me some step by step instruction to be followed, thanks.
Best Answer by Michelle Karla
Answered By 15 points N/A #187413
Hi
In order to change the icons of any folder in Windows7 you need to follow these steps:
1. Select the folder and right click on it.
2. Select properties from there.
3. An interface would show up and there will be several tabs from which you have to select the "customize tab"
4. From there under folder icons you will see an option "Change folder icons".  You have to click it.
5. A new interface would show up from there you can select any icons. You can add your own icons by selecting "Browse" from there; you have to include the destination of your icons which you wish to use.
6. Select them and press OK and then again OK and you are done.
Michelle Karla
Answered By 0 points N/A #187414
I assume that you are using Windows 7.
Here is a step by step guide in personalizing your desktop icons.
1. Right click into an empty space in your desktop and select Personalize.
2. Click on the Change Desktop Icons link found at the upper left of the window.
3. To change the icon for a Desktop Icon
  • In the middle pane, select a desktop icon that you want to change and click the Change Icon button.
  • Select an icon that you want to use instead, use the Browse button to locate the images you wish to use.
4.If you wish to revert back what you have done with your icons you can just simply click the Restore Default found beside the Change Icon button.
