Hi Guys,
I don't know how to code using PHP. My wordpress theme has this footer note that I really want to delete. I'm not sure if that is allowed because I read that the reason why the wordpress theme developers are putting links on the footnote so that they will be credited for their work.
It's ok if the footnote only says "Powered by WordPress" but there are times that the links are too much. I hope there is a fix for this because I really wanted to have my site look neat without any ads. Please let me know if you guys has solutions.
Thanks,
Brian
How to edit the footer note of a WordPress site using PHP?
Hello Brian Parker,
Edit the following code in footer:
Hope this will work
Thank you
Hello Brian PHP is an extra ordinary language in which as it is said to as scripting language and the integration with PHP is done easily as it is not so tough to do like as many other languages used for the integration purpose.
The integration can be done mainly with using the JOOMLA CMS subsystem and the integration is done with PHP in the way that it is defined as the CMS system.
As you said there is some error in the flash builder and as you said the problem is completely with the database connection when using to load PHP into the database.
Its very easy to work with the footer when we are working in PHP but in case of word press it is not easy as it may require some other scripts dynamically.
Thank You.
