How to edit funny snow display pictures? I was asked to choose a picture and edit those in your most creative way. I need your suggestions on the best editing software to be use. Also share with me those amazing features; I also need a tutorial for a specific software.
Waiting for your support, thank you.
Hi Christine,
You can use Adobe Photoshop, any version will do, but you will have to purchase the license of this one. It has many features and is easy to learn.
Or you can use Gimp anyway if you don't want to purchase. It is an open-source software and most of the features are the same with Photoshop, but I found it not as easy to learn myself. But you can try it, see the tutorial on https://www.gimp.org/tutorials/.
Right now, Adobe Photoshop is the best photo editing software and has almost all features, but it will cost you some money. If you want to use free software, I can suggest you some names.
Paint.net
Photopos
PEdit
Irfan View
Stoik Imagic
Digikam
Visual Box
My Paint
I think these software will help you in every possible way. You can also try some tutorials on the following site:
