How To Edit Google Calendar In Outlook
Hi. I am using MS-Outlook. I want to know the steps to edit Google calendar in outlook. Can you please suggest me the steps for the same? Thanks in advance. It is urgent so please reply ASAP.
Hi. The steps to edit Google calendar in outlook are as follows-
1) Install the Outlook Google Calendar Sync file and then double-click on the file
2) In the security warning dialogue box, click on install
3) Wait till the installation completes
4) In the Microsoft Outlook dialogue box, click on allow
5) After the Outlook dialogue box opens, click on settings
6) Then select the calendar which needs to be synced
7) Within the Outlook Google Calendar Sync, when you access the calendars, the webpage will open in the browser. Click on accept
8) A webpage will open with a code which needs to be copied
9) Paste this code in the edit space and click on OK
10) Select the calendar which needs to be synced from the list
11) After the Outlook Google Calendar Sync opens, select how, when and what options in the window from the sync options
12) In the application behavior option, make changes to the username and password and then click on OK
13) After all the settings are made, click on the sync tab and click on save
14) At the bottom of the window, there will be an option of start sync which needs to be selected
15) After the sync gets finished, a finished sync dialog box will be displayed
16) After you are done with the process, click on X button displayed on the top-right of the window
Hope we helped.
Notifications
