anonymous
7060 points
Posted on - 07/19/2011
Please tell me how can I edit my posted question in Techyv.com. I want to add some more into my question I asked before. I know its an easy one definitely but just wanted immediate help for me and anyone like me.
How to edit my posted question
Hey Hi,
This is very simple. Just you need to create an account on this site by clicking on sign up at the right corner.
Provide some information and you will become a member on this site. Without becoming a member you cannot post questions on this site.
Once the question has been posted and saved. To edit the question and add something to it you will have to Login and go to the question which you have posted.
You can find the question from the questions section. Then an EDIT button appears on the bottom.
By clicking on it your question will be edited. Just make changes and click on Save and your question is edited and saved.
David89
This is the simplest question I had ever seen!
You said that you want to edit your posted question, so that you have an account. Also, after posting you have to go to the question and look at the down of the screen on the right side. You will find a green button "Edit".
You have just to click it and that's all!
Hi!
To edit a posted question, first, you have to login (that is, if you already have an account here. If not, the sign up). Go to your posted question. Scroll down, at the right side of the window you would see the "Edit" button. After editing your question, just click "Save" and you're done.
mozak
5 points
I think you need to register for you to have a legit access to your post, so create a post then submit it, and if your post is not complete you can edit it by clicking edit. See below, also be sure no Solution is posted as after the solution is posted you cannot get the "Edit" option enabled.
Note: all forums have this edit option so you need to have an account so that you can use that privilege.
Also to edit solutions can see the other image.
