How To Edit Pdf Files On Windows.
What is a PDF file? What is the full form of PDF? How to edit pdf files on windows? Can we directly edit the PDF file in Windows or do we need a software to edit the file?
A PDF is a format of the file where we present, and document is exchanged readily without any assistance of software. PDF stands for Portable Document Format. Whenever we open a PDF, it directly opens in Adobe Acrobat Reader. To edit the PDF file in Windows download Adobe Acrobat reader. This reader is already installed into the computer.
So, to edit the PDF document open it in Adobe Reader and to the right select edit option then, edit however you want to edit cut, paste, remove, copy, etc.
