Hi techyv,
How to edit pdf javascript code? I downloaded some pdf files that contain javascript code from a friend. Is there a way that I can edit the javascript codes in the pdf file? I can’t seem to find the edit button that will allow the user to add or change some written text in the form.
Hoping for your help. Thanks.
How to edit PDF JavaScript code?
Pdf format itself was not originally designed for continual editing, when you save changes to the structure causing its editing is very problematic. The main advantage of PDF is that you can view documents on any computer, without losing the formatting and other niceties. PDF is independent of the operating system. All programs can edit pdf documents of paid and have different functionality. For minor changes – editing text and title fields will approach all the editors, but only one global change – Adobe Acrobat Pro. I should also mention that the editing of the document is strongly dependent ways to create pdf document.
You can use the following programs for editing pdf:
Adobe Acrobat Pro
Foxit PDF Editor
Jaws PDF Editor
VeryPDF PDF Editor
    There is the ability to edit pdf documents on the Internet online services such as:
PDF Hammer ( http://www.editpdf.com ) – fast, easy and free service for editing documents pdf.
PDFfiller (https://www.pdffiller.com/) – a free online pdf editor.
PDFescape (https://www.pdfescape.com/windows/) – pdf editor with advanced features.
So you can first convert pdf document in Word and edit it there.
Regards!
