Hi guys,
How to edit rotating avi video clips? Me and my group mates are making some music video for our video editing class. What is the best software you can suggest to use in editing videos? I want to stop those rotating scenes for it is not advisable to be viewed.
Expecting some help, thank you.
Hi Brenda!
You can simply use Windows Movie Maker. If you are using Windows Vista, then it is already installed in your system. But if you are using Windows 7 and Windows 8, it is free for download at the Microsoft Website. WMM can import and edit videos in the AVI format. Though, the output formats are Windows Media Audio (WMA or .wma) and Windows Media Video (WMV or .wmv) only.
If you want to save your video in other formats like AVI, MP4, and MOV, then use Adobe Premiere, Sony Vegas Pro, and other similar video editors. You will have to buy them but you can download and use the free trial versions.
There are some programs that you can use to create videos but hey are much more expensive and you just need to use them for the sake of personal use. However there is software named as camtasia studio that you can find over the network and after installing it you will be able to make your required videos.
Smith Thompson
