How to Edit Text in Paint
I have drawn several graphics in paint which I would like to add to various web sights I'm developing. On some of these graphics, I've placed text. On a second look, I realize that I'm not completely happy with the text or the position. Is there any way to move or edit the text once it has been added to a paint graphic?
Best Answer by ashlee
Answered By 0 points N/A #81102
Hi ,
I saw your file here is the solution for that you can Edit the text using the text toolbar. If the text toolbar does not automatically appear,on your text then right-click within the text box and select the text toolbar option from the menu that appears. The Possible editing options include the font style or size can be able make the text bold, italic or underlined. You can even Change the color of the text by clicking in the text box and on a new color in the color box menu. The text can be edited till you click outside of the text box.
Note : If you have saved the image in windows 7 then there is no possibility of editing it you can only cover the text with new text box.
Answered By 0 points N/A #81105
Click the A (text) on left side toolbar < then write something < and if you want to change the font or size < click View >> Text Toolbar < Highlight the text that you want to change, right click and then select text toolbar < there you can do the formatting.
