How to edit VCF Notepad
Is it possible to edit VCF file using any text editor like Notepad.
If so please advice on how to edit VCF Notepad and how to save it.
Is there any standard procedure to manage the text in the VFC file, so that it can be exported and imported as VCF file, even after doing the editings.
Please advice. Thanks
Answered By 0 points N/A #167506
Hi Ralph,
Virtual business card or vcard is  used to share business information.These files are stored with .vcf extension. These  files can opened with any text editor .The file data is in simple text format.
Follow these steps to vcf file in notepad
1) Open the notepad
2) Go to file menu select open option.
3) In the open dialog box set type of file as all files
4) Select vcf file you want to read
5) Click the open button.
For editing the vcf there are many editors available like notepad++.
Answered By 590495 points N/A #167507
One type of file format that uses the VCF file extension is the vCard format (.vcf). It is Office Outlook’s way of storing contact information in a file. This way you can send your contact information or your friend’s contact information in a form of a file.
When the person receiving the file opens the vCard attachment or the “.vcf” file, a contact form will open showing the contact information. When the person saves the file, it will be added directly to his Office Outlook contacts saving all the information. But if you don’t have Office Outlook and you’re wondering if you can open it with any text editor programs such as Notepad, yes you can.
The vCard format is a human-readable text file. You can open it with Notepad or Wordpad. If you want to add contact information to the file, just follow the default formatting on the previous entries. Another file format that uses the VCF file extension is the Variant Call Format or VCF. It is a format of a text file used in bioinformatics for storing gene sequence variations.
