How to edit video with Audio Swap
Hi All
I want to know about the working of Audio Swap. Does audio swap help changing the audio only? Can video editor with audio swap is also possible? How does it work?
Hi All
AudioSwap is a feature which allows you to easily add music to your YouTube videos from a library of licensed songs. To use it, try these steps:-
1. Login to your YouTube account
2. Click 0n the " Try AudioSwap" button
3. Choose the music that you want to have in your video from YouTube's audio library. Or if you want YouTube to choose a song based on the length of your video, select "I'm Feeling Lucky" option.
4. Preview the video by clicking on "Preview" button.
5. Click on the "Publish' button
6. If you want to change the music that you just selected, search for another song and once you decided to replace it, you cannot get the previous version back
Laz Zebbena
