How effective is a Google chrome desktop cleaner?
Hi all
My current operating system is windows 7 64 bit and has a default browser of Google chrome. I would like to clean all the possible cache in my browser as well as to check the desktop’s status. I want the best for my computer system and I need your opinion about Google chrome desktop cleaner.
Thanks and have a nice day.
Best Answer by Aliree Marqueta
Answered By 0 points N/A #165195
Hi Marie,
If you have Google chrome as a your default browser then it is good for you to have it. There are many desk top cleaners which need to be downloaded and installed but the best thing about the Google chrome's feature is that it is already integrated and you can check the status of your desktop while cleaning your cache.
I would highly recommend Google Chrome for you at this point because it makes browsing easy and the browser takes little space for add-ons to appear and takes less time for them to load. Regarding the Desktop Cleaner feature, it organizes and cleans unnecessary files in your desktop to keep it clean and tidy.
Thank you
Answered By 0 points N/A #165196
Here, you need  help for using Google chrome desktop cleaner.
I think some good tutorials and help manuals can help you solving this problem.
You  described you pc configuration is windows 7 64 bit.
In this stage You can use c cleaner.how to use it, You can get this from this link
After install C cleaner you must clean the registry file to.
You Can get to know exact way to learn how to clean Google chrome from here.
