How Enable Age Of Empires – Play Online Mode?
I have a computer on which I play my favorite games. I want to play the Age of Empires with my friends. How can I start the Age of Empires play online option?
It is fun to play multiplier with your friends. The new Age of Empires game has a multiplayer option where you can play against and with gamers from all over the world. You just need to follow the steps given below. They will help you learn the basics of multiplayer gaming in Age of Empires.
1. Start the game
2. Open Campaign
3. Select game mode
4. Click on the ’Multiplayer’ option
You are set to play online.
If you haven’t installed the game yet, make sure your computer meets the requirements before you install it. So, you should check the game’s system requirements or the game specifications. Also, there are different versions of the game so better check which version you want to play. There are two possible ways to play the game “Age of Empires” online.
The first option is “Voobly.” Visit Voobly Free Social Gaming Network and download the Voobly client. Once installed, run Voobly then create your account if you don’t have an account yet. If you already have, just sign in to your account. Once your account is created, download the lobby client.
Once the lobby client has been downloaded and installed, try updating it if it’s possible. After that, click “Games” to visit the game lobby. It will show you all the available games and all versions of “Age of Empires.” Select the game you want to play to visit the game’s lobby. After that, start or join a multi-player game.
The second option to play “Age of Empires” online is with GameRanger. Visit GameRanger and download the client. Note: before you download or install any of these programs, “Age of Empires” should already be installed on your computer. Now, if you have a problem with GameRanger, here’s a workaround. Download GameRanger-Not-Responding-Fix.7z and unpack it using 7-Zip.
Once unpacked, look for the folder called “GameRanger-Not-Responding-Fix” and rename it to without quotes “GameRanger”. Next, make sure GameRanger is not running. Press Ctrl + Shift + Esc to bring up the “Windows Task Manager” then go to “Processes” tab. Now, look for “GameRanger” on the list. If you see it, kill it. Select “GameRanger” then click “End Process” and then select “End process” to confirm.
After this, right-click the GameRanger folder you just renamed and select “Copy.” Next, navigate to one of the following locations whichever is available:
These folders are hidden by default. If you can’t see them, in Windows Explorer, click “Tools” then “Folder options.” Go to “View” tab then under “Hidden files and folders” section, select “Show hidden files, folders, and drives” then click “OK” all throughout. Now, press Ctrl + V to paste or begin copying the folder.
When you are prompted to overwrite files, click to select overwrite all. When you are finished, see if GameRanger runs without error.
