I am facing a problem with my USB flash memory. Whenever I attached it to my computer, it doesn't appear auto run massage. My Auto Run option of USB is blocked by my security software. I want to choose a different program to open my USB on start up. I want to enable autorun message on USB. I need your assistance in this regard. Waiting for a positive response.
How to enable autorun message on USB
To enable AutoRun for your USB flash drive, you need to change a value in the Windows Registry.
These are the steps:-
1. Go to Start Menu > type regedit on Search Bar.
2. Go to HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionPoliciesExplorer.
3. Check value for NoDriveTypeAutoRun. If its B5 then AutoRun for USB has been turned off.
4. Its default value is 91, so change it to 91.
5. To change it, right click on NoDriveTypeAutorun and select modify.
6. The same way changes it from HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionPoliciesExplorer.
Laz Zebbena
