How to enable find function in form access?
50 points
Posted on - 09/22/2012
I have created a database about product data using MS Access. I have this column where it shows the status of the product whether it is new, refurbished or repaired with ID Name called “Prod_Stat”. Now, what I would like to happen is to enable a find function in form access where the user can use a search feature.
By using a specific “Prod_Stat” value, the user will be taken to that record on a form I have stumbled upon this Search Code but it appears to be not of help.
