How to enable the free vpn on demand iPhone feature ?
I have read that in order to get the free vpn on demand iphone feature work I must generate and install an authentication certificate.
Due to the complexity of such an operation I turned to you looking for advices regarding the easiest way to make vpn work on the Iphone.
Thanks in advance.
Answered By 0 points N/A #195473
Hello Alice Macek,
I understand you want to use a VPN connection to connect to the internet in your iPhone. It is very easy to do that, just go to the Apple store and download Hotspot Shield, I am giving you a download link below. If you want it for free then you have to bear with the ads this software will show.
Link: https://itunes.apple.com/pk/app/hotspot-shield-vpn/id443369807?mt=8
