friendz01
Posted on - 10/02/2011
How to enable Gtalk for many user? Gtalk for many users is very essential for today. Suppose we have many Gtalk account but one Gtalk is support for one System. So how we enable Multi uses for Gtalk means we can be online with our many Gtalk account.
brook
How to enable GTALK for many user
By default Gtalk allow you to run only one instance of the program at the same time.
There is a simple trick to change this so that you could run multiple instances and login with different user accounts.
Assuming « C:Program Filesgooglegoogle talkgoogletalk.exe » is Gtalk’s default installation directory,
Right-click on the desktop.
Choose « New » then « Shortcut » and copy/past the following text under the label « Target » :
"C:Program Filesgooglegoogle talkgoogletalk.exe" /nomutex.
Name the new shortcut « Gtalk Xlogs » for example, and you are done.
Now every time you need a new Google talk instance just run it from the new desktop shortcut.
Hi friend,
You can use or enable Gtalk for many user. This is not a big task. Yes Google talk for many users is very essential for today. So many people wanted to enable Gtalk for many users. That means multi uses for Google talk. In order to do these just follow simple step.
One option is Run Google talk with this “/nomutex” following command or switch. It will allow you to log in with many ids at the same time for the same computer.
Other option is you can download some software that has support multi uses for Google talk. There are many software for it. Just search and find a sweet able one for you.
