How to enable opera for dap for windows phone?
I have windows phone and would like to use opera as a browser. I would like to know how to enable opera for dap for my windows phone?
First Install DAP in your phone then copy “dapop.dll” file from DAP installation folder in to Opera plug-in folder (you will find it Operaprogramplug-in). Now restart Opera, and make sure that the plug-in is properly installed. To verify go to Tools, Select Advance and select Plug-in to see whether it is listed or not. Go to Tools > Preferences > Advanced > Downloads and edit the MIME type to “Use Plug-in”
Simply you need to find the mobile version of opera and then you need to install it to the software category and you will be able to use the software. As your phone is windows based phone so it will be very easy to use such software. Just you need is to put it to your computer, install it if required and then use it as you want.
Smith Thompson
