How to enable the option sine on Nvidia GTS 450
Hello technicians,
I installed the DX11 and the High Resolution texture pack. I have an NVIDIA GTS 450 with 1 GB of GDDR5 RAM. The graphics card is compatible with is DirectX 11 and it fits the requirements for the DirectX 11 and the High Resolution Texture pack.
The problem now is that I can't enable the option sine when I try to install it gives me an error message.
Where could be the fault?
I really need help.
Regards
Error
On startup, line 91: attempt to index global ‘tbVersionInfo’ (a nil value)
