How to enable or disable the folder option in XP?
Hi devol,
This is a problem for me too, i like to show my hidden files but i can't see it so i search the internet and look what I've got. This will work.
Copy paste it to notepad name it.
"fixfolder.reg" and save it to your desktop
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOTFolder]
@="Folder"
"EditFlags"=hex:d2,03,00,00
"TileInfo"="prop:Size"
[HKEY_CLASSES_ROOTFolderDefaultIcon]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,
00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,00,68,00,
65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,33,00,00,00
[HKEY_CLASSES_ROOTFoldershell]
[HKEY_CLASSES_ROOTFoldershellexplore]
"BrowserFlags"=dword:00000022
"ExplorerFlags"=dword:00000021
[HKEY_CLASSES_ROOTFoldershellexplorecommand]
00,5c,00,45,00,78,00,70,00,6c,00,6f,00,72,00,65,00,72,00,2e,00,65,00,78,00,
65,00,20,00,2f,00,65,00,2c,00,2f,00,69,00,64,00,6c,00,69,00,73,00,74,00,2c,
00,25,00,49,00,2c,00,25,00,4c,00,00,00
[HKEY_CLASSES_ROOTFoldershellexploreddeexec]
@="[ExploreFolder("%l", %I, %S)]"
"NoActivateHandler"=""
[HKEY_CLASSES_ROOTFoldershellexploreddeexecapplication]
@="Folders"
[HKEY_CLASSES_ROOTFoldershellexploreddeexecifexec]
[HKEY_CLASSES_ROOTFoldershellexploreddeexectopic]
@="AppProperties"
[HKEY_CLASSES_ROOTFoldershellopen]
"BrowserFlags"=dword:00000010
"ExplorerFlags"=dword:00000012
[HKEY_CLASSES_ROOTFoldershellopencommand]
65,00,20,00,2f,00,69,00,64,00,6c,00,69,00,73,00,74,00,2c,00,25,00,49,00,2c,
[HKEY_CLASSES_ROOTFoldershellopenddeexec]
@="[ViewFolder("%l", %I, %S)]"
[HKEY_CLASSES_ROOTFoldershellopenddeexecapplication]
@="Folders"
[HKEY_CLASSES_ROOTFoldershellopenddeexecifexec]
[HKEY_CLASSES_ROOTFoldershellopenddeexectopic]
@="AppProperties"
[HKEY_CLASSES_ROOTFoldershellex]
[HKEY_CLASSES_ROOTFoldershellexColumnHandlers]
[HKEY_CLASSES_ROOTFoldershellexColumnHandlers{0D2E74C4-3C34-11d2-A27E-00C04FC30871}]
[HKEY_CLASSES_ROOTFoldershellexColumnHandlers{24F14F01-7B1C-11d1-838f-0000F80461CF}]
[HKEY_CLASSES_ROOTFoldershellexColumnHandlers{24F14F02-7B1C-11d1-838f-0000F80461CF}]
[HKEY_CLASSES_ROOTFoldershellexColumnHandlers{66742402-F9B9-11D1-A202-0000F81FEDEE}]
[HKEY_CLASSES_ROOTFoldershellexContextMenuHandlers]
[HKEY_CLASSES_ROOTFoldershellexDragDropHandlers]
[HKEY_CLASSES_ROOTFoldershellexDragDropHandlers{BD472F60-27FA-11cf-B8B4-444553540000}]
[HKEY_CLASSES_ROOTFoldershellexPropertySheetHandlers]
DOUBLE CLICK IT.
AND yes.
Your folder option is back.
