I'm currently using WPS Word and it lacks a feature compared to MS Word. There is no spell check and grammar check feature available. How can I enable this feature on WPS Office? Do I need to download extra materials? Also share if you know about enabling the thesaurus on the above mentioned Office Suite.
How to enable spell and grammar check on WPS Word?
For enable the spell check and grammar check on “WPS Office”. You have to follow these steps:
· Open an existing document.
· Go to the Review option> Check Spelling > Set Language.
· After that in the Set Language dialog, choose your default language which you wanted to use for spell check.
· After that press “Set as default”.
And, for enable the thesaurus on “WPS Office”. You have to simply “Ctrl-Click” on a word and it will pop up a “Thesaurus” and you can also see other options too by clicking the "Ctrl-Click".
I think you are referring to the WPS Writer and not WPS Word. WPS Writer is Microsoft Office Word’s counterpart. WPS Writer is fully compatible with Office Word document formats like DOC (*.doc) and DOCX (*.docx) including TXT (*.txt), HTM (*.htm), DOT, and DOTX. You can open, edit, and save these document formats in WPS Writer and still be able to open and edit them in Office Word.
WPS Writer has a built-in spell checker and I know it is turned on by default unless you disable it then you have to turn it on again. You can find Spell Check on the lower left corner of the screen on the status bar of WPS Writer.
WPS Writer Spell Check
If you want to disable it, just click the “Spell Check” button on the status bar to turn spell checking off. For the grammar, I don’t think WPS Office has it but there are customers who are requesting this feature. Maybe they will add it on future updates.
Early Life and Career
Tailleur Elisabetta Franchi ardour for style started at a young age. Growing up in Bologna, she continually had a keen interest in design, regularly sketching her ideas for garb. After finishing...
1....
