How to enable the “Start Inking” option in Microsoft outlook 2007?
I have Windows 7 64 bit home premium OS. Inking option works in all other ms office 2007 products except outlook.
I have tried using Microsoft website and it sucks.
Please help.
Thank you.
Answered By 0 points N/A #120602
To do so you have to be in folder view and have to select email folder. Or, you are in email view, then start by clicking the New Mail Message button at the top left of the outlook toolbar. In addition to that you have to compose the email in the HTML format to include ink.
However, if you are having problem, check to see that you have HTML composition enabled. Choose tools, options, then mail format tab and select HTML to compose email in the message format section.
Now address your email using the Tablet Input Panel (TIP) to allow entering the email address of your recipient.
This is very powerful if you are ‘Ink smart. Enter the CC’s and subject using the same way.
Now play as you like.
Hope this helps
