I am using galaxy s2. Whenever I am connected Bluetooth and I would have to find the voice command button and give command through Bluetooth. But I can't do it from yesterday because my command button is not working. How to enable voice Command galaxy s2 Bluetooth?
How to enable voice command Galaxy s2 Bluetooth ?
Hello Karla,
It looks like you want to enable voice command in your Galaxy S2 Bluetooth. This is a common problem for hands free users and you need an application on your S2 to resolve this problem. Most users complained that whenever they are connected to Bluetooth while driving, they would have to actually pick up the phone and find the Voice Command button and then give commands over Bluetooth instead of the way most phones handle it by letting you just hold down the button on the Bluetooth headset.Â
The application you can try is Hands free with choice dialer. You can get it from the following link but its not for free
https://play.google.com/store/apps/details?id=com.resounding.choicedialer.pro2
I hope this helps.
