How to enable Windows 7 welcome sound on start up?
I have formatted my laptop and installed a fresh copy of windows 7. But I cannot hear the welcome sound in startup. Can you explain how to enable win7 robot welcome sound?
You can change the startup sound of your Windows 7 by clicking on the Start menu > Control Panel > Hardware and Sound > Sound and then change the start up sound depending on what you will choose. If you cannot hear any sound after formatting your laptop, check on the device manager if the sound driver is properly installed.
If not, you will need to install it. Go to your laptop's manufacturer website and find the correct driver.Â
Check whether if you cannot hear any sound at all. Then you haven’t installed your sound drivers. Do the below steps:
