How to enable Windows Desktop Clean up
In Microsoft Xp, there is a feature that enables you to clean your desktop my friend told me that but I have a hard time looking on how to enable it. Can somebody please help me how to enable it?
Hello.
Yes Window XP does have a feature the enables you to automatically clean you desktop.
Just follow these instructions.
Click on START -> CONTROL PANEL -> APPEARANCE AND THEMES -> DISPLAY.
On DISPLAY properties box click DESKTOP -> CUSTOMIZE DESKTOP
On CUSTOMIZE DESKTOP dialog box under DESKTOP CLEANUP click CLEAN DESKTOP NOW then click OK.
Now DESKTOP CLEANUP wizard starts.
To remove unwanted shortcut
When the DESKTOP CLEANUP WIZARD start click NEXT then it will pop out a dialog box of your current desktop shortcut, just select the desktop shortcut you want to remove then click NEXT to complete the DESKTOP CLEANUP WIZARD then click the FINISH button.
HOPE THIS HELPS YOU.
Windows Desktop Cleanup is the easiest way to clean unused icon in your desktop. In enabling this feature just follow this steps:
5. Click “Ok” to exit “Desktop Items” window.
6. Click “Ok” to exit “Display Properties” window.
Or if you want to run the desktop clean up immediately just follow steps 1 to 3 and click the "Clean Desktop Now" button.
The “Desktop Cleanup” wizard only removes selected shortcuts and store them in an automatically created desktop folder called “Unused Desktop Shortcuts”. Whenever you want to retrieve the unwanted shortcuts just open the “Unused Desktop Shortcuts” folder.
