Hi techyv,
How to encrypt web source code free? When uploading or sending some source code information from the internet, I am having second thoughts about intruders. I have to encrypt the files and zipped in a rar file before uploading or sending it online. Can you help me to get this done?
Hoping for your help. Thanks.
Hello Marie,
To encrypt web source code, scramble the source of any chunk of code, or the entire web page, you may use this creative script. I give you an exact web page where you can encrypt web source code.
http://www.dynamicdrive.com/dynamicindex9/encrypter.htm
Dear Marie Philips,
If you are keen on the security of your source codes when sending it you can encrypt it by WinRAR.
1- Right click on your file and select add to archive.
2- From the tab advanced select set password.
3- Write your password and you must use letters mainly not numbers in it.
Or there is another way to encrypt your codes with online encrypting website on the following link.
May be it is a part of a plan so that in your current page (encrypted) whoever assesses the sender’s signal, will face that is challenging the name. The quality of being encrypted can depend on many factors and it can differ on good plans whatever you get. The web pages may be cloned pasting in a good editor and it should be followed.
Actually encryptions of web pages are like a password safeguarding of pages built on html. You need to guard your html page from unauthorized taking outs and for duplicate defending of information through obtaining or keeping in compact disk or propagating by means of email.
