How to enlarge PDF to multiple pages
I have a single page PDF file and I want to print it. On single print out I cannot see the picture properly. I want to enlarge PDF to multiple pages, so it can print out on multiple pages. Please tell me how to enlarge and print single page on multiple pages.
Best Answer by Waall Mike
Answered By 270 points N/A #180062
Hello Isabella,
Let me give you the steps on how to enlarge and print pictures from pdf. This is quite easy and simple, all you need to do is :
1. Open the PDF file using a PDF reader or application like Adobe Acrobat Reader for Windows or Preview for Mac.
2. Go to "File" menu and then select "Print"
3. Select the appropriate printed attached to your computer and then click "properties" or "page setup" for windows and Mac respectively.
4. Select the page that you want to print and then either "Scale" the image bigger or "fit to page".
5. Review the size and the layout of the media that you want to print on the preview and then click print.
Hope this helps you with your problem.
Waall Mike
Answered By 0 points N/A #180063
Hi Isabella!
There are many ways to solve this issue. For the easiest way to enlarge pdf to multiple pages you can follow these steps:
1. Click on the Print button.
2. Here you can set page scaling to tile all pages.
3. Then you will be able to adjust the Tile Scale to your required percentage.
4. Check in print preview how many pages will be used.
Thanks
Tritt Rochelle
