Hi,Â
I need my internet connection to be more reliable and fast. How do I enter the DNS manually in Windows XP.Â
Please give a complete instructions on how to do it.
Below is the sample picture of my network connection, where do I go from here?
Thanks!
How to enter the DNS manually in Windows XP?
Good thing that you already have a screenshot of Network Connections where it has Local Area connection icon is located.
Assigning DNS is usually done if you want to use specific Domain Name Server.
In the screenshots, it has 2 icons for Local Area Connections. You will need to identify which of those 2 icons is the default connection for your Internet.
But basing in your screenshot, what you need to do are the following;
Right click on Local Area Connection
Left click properties
Scroll down a bit and Look for Internet Protocol TCP/IP
Hightlight on it, then click on properties
Do assign a specific DNS in Manually type DNS server
Usually, DNS are 4.2.2.1 up to 6Â
Just follow me
Double Click
And then this image will appear for you
So tick on " Use the following IP Address" and also on " Use The following DNS server Address" and put your IP addresses in all boxes but i think the prefered and alternate ip address for open DNS are 208.67.222.222 and 208.67.220.220 then press ok and if you want to change DNS or your IP Address setting press on Advance
Hope these Solution helps you
