How to erase browsing history from Mac OS
Dear All,
I am using Mac that runs OS Safari 6.0. I want to erase all the browsing history but have no idea how to do it. Can anyone tell me how to completely history from mac?
Dear All,
Hello there Beeky,Â
Removing history from any browser is easy and all you need to do is follow the following steps :
1. Open Safari > on the menu tab go to HistoryÂ
2. Choose "Clear all history" on the tab, you'll see this at the very end of the tab
3. A pop up will appear asking if you're sure of your action. Note : it will ask if you want to reset top sites, if you do so leave this checked
4. Click "clear" and you're done.
Hope this works for you.
Waall Mike
Good ady Beeky
IÂ saw someone showed you how to clear you browsing history. You can visit web pages without recording your browsing history.Itis called private browsing. When safari is open go to Safari, private browsing,
You will get a popup window to activating the private browsing, by pressing ok.
How will you know private browsing is activated? Next to the address bar will a private icon appear.
Hopefully you can you use this.
