How to execute community website script?
Hi Experts,
I need to execute community website script.I have developed a website using a scripting language and want to execute it.The code is mixed with javascript,html and xml.Can anyone give me step by step guidelines to execute the code.Thanks.
Roger Neil
Answered By 0 points N/A #132981
You have mentioned that you developed a website using scripting language combination with JavaScript, html and xml. Web development is vast topic. As you have developed a site so you know better. Your question regarding the execution of the code is not clear. However, we use scripting language to add some tiny programming in an html document.
In this field people are code writer not programmer. If you insert correct scripting code in the document it will get automatically the pop up or on click or on load function. The complete website development is a complicated task. You need to know the all in details.
I hope you understand it.
