onam ophir
40 points
Posted on - 08/31/2012
Hi Experts,
I am having online telephone  directory which has being coded in web script. I want to know how to execute the code with parameters. Does anyone know there telephone directory web script. Thanks.
Onam Ophir
Execute the Code for Online Telephone Directory Webscript
Hi Onam Ophir,
I have attached some links that may help you in finding the best solution with your concern. The sites has a lot of information that you may need in making online Directory. It is just for reference. Kindly click the links below:
EDirectory: Why use eDirectory?
Ehow: How to Make an Online Directory
Hope that would help you a lot.
Hi Onam Ophir,
Here's a solution to your script problems in telephone directories:
1. Start by associating phone numbers with a particular name, using the code in the attached .TXT file.
2. Keep the list sorted to enable you to add new names and numbers in the future, using the code in the attached .TXT file.
3. Save the directory in a file, using the code in the attached .TXT file.
Hope this helps.
Murakami Wyatt
