How to execute VCE format files?
I downloaded a desktop exam yesterday. I Goggled it and it seems it is a VCE format. So how to execute VCE files? Do I need s separate software to use it?
Hello Scott,
VCE format is an extension associated with Visual CertExam Software. If you want to open that file, you need to download it first and then install it. You can download it form this link – https://www.avanset.com/.
After installing the software, you can easily open that file give your exam.
Hope this helps and good luck with your exam. 🙂
Hello Green,
To run the VCE file you will need to download Visual CertExam software. After downloading the software you can easily open the file. I can suggest you one more thing, if you have a PDF printer then you can convert the file into PDF simply. For that, you have to open the exam paper by launching Visual CertExam then go to the Print option from the File menu. After that, select your PDF printer finally select the exam you want to save as PDF. Now click ok to confirm it. Hope this could be a help.
Good luck.
Notifications
