How to export Adobe docs to PDF
Hello everyone,
I am using Adobe Acrobat reader. I need to export adobe docs to PDF, so I need a software of it.
Where I can find it?
Please reply me.
Hello everyone,
Please reply me.
Hi James D Costanza,
Want to doc file to PDF file? There are many software which can do your work easily.
Now Microsoft word 2010 is giving you this facility by using Microsoft word 2010 you can make PDF file easily. If you are not using Microsoft word 2010 then you should use converter to make a doc to PDF file.
Here I am giving web address where you can get –
If it is not working as you want then I think you should use MS office 2010.
Best wishes for you
Hello, James
Hope you are fine.
You want to convert your doc file to PDF file.
I can help you by giving you some links to download docs to PDF converter
It is a free software and very easy to use. By this software you can convert doc file to PDF file and PDF file to doc file.
This software is also useful to translate.
They are easy to download and install. You can try them.
Hope you will get your answer.
If you need some Microsoft Office Word documents in PDF format, try converting them online. Go to Convert documents and images to PDF. This online tool not only allows you to convert Microsoft Office Word documents to PDF format but also images. You can even use it to take a screenshot of a website and have it converted in PDF format.
The tool supports the following conversions: DOC to PDF, DOCX to PDF, TXT to PDF, and many more. You can upload the documents in different ways. You can select the file directly from your computer or upload from Google Drive or Dropbox. You can also upload by URL if you uploaded the files on your web server. Once the file is uploaded, just click “Convert file” to start converting.
You can only upload and convert one file at a time. Once the conversion is complete, the file is downloaded automatically to your computer or you can download it manually if the auto-download didn’t work.
Notifications
